Changing a verbatim control path
To change a verbatim control path:
- In the Trial Objects window, double-click the name of the coding mapping object.
The Data Mappings window opens with the mapping object name selected.
- Expand the node of the visit that contains the verbatim.
- Right-click the verbatim node, and select Edit Verbatim Path from the right-click menu.
The Build RefName dialog box appears.
- Click Back until the RefName list contains the level from which to rebuild the RefName path.
Note: You can change any RefName except the visit. To create a verbatim control path starting with a different visit, you must create a new verbatim mapping in that visit.
- Use the Build RefName dialog box to specify the RefName path. For more information, see General instructions for using the Build RefName tool.
- When the RefName path is complete, click Done.
- InForm Architect application enforces restrictions on verbatim control path definition. For more information, see Verbatim control path restrictions. If the selected control results in a valid control path, The InForm Architect application replaces the path in the component definition you are editing.
