Verbatim control path restrictions
The InForm Architect application enforces the following restrictions on verbatim control paths:
- The verbatim control path must be unique within a mapping.
Note: To use the same verbatim with multiple dictionaries, create a separate mapping for each dictionary.
- Verbatim, code target, and context item control paths must be:
- In the same visit if the visit is repeating.
- On the same form if the form is repeating.
- In the same itemset if the coded data appears in an itemset.
- Different from each other.
