Verbatim dictionary updates
You can change the dictionary for a verbatim by updating the Dictionary property of the verbatim. For example, if you install a new version of a dictionary, you can update the verbatim mapping definition to use the new dictionary version.
When you select a new dictionary definition from the Dictionary property dropdown list, the InForm Architect application:
- Checks for matching code targets and context items in the two dictionary definitions and preserves the existing control paths defined for code targets and context items that match.
- Adds new code target and context item nodes to the verbatim control mapping definition.
- Warns you if any code target and context item mapping definitions do not exist in the new dictionary definition.
- Removes those code target and context item mapping definitions if you confirm the Dictionary property change.
