Removing a code target path
To remove a code target path:
- In the Trial Objects window, double-click the name of the coding mapping object.
The Data Mappings window opens with the mapping object name selected.
- Expand the Visit and Verbatim nodes containing the code target path you want to remove.
- Right-click the Target node, and select Clear Target Path from the right-click menu.
The InForm Architect application removes the RefName path from the definition of the code target.
