Identifying context items
A context item provides additional information to enable coding of a verbatim. The WHODD dictionary uses context items to provide the following information:
- Route of Administration—The route by which the drug was administered.
- Indication—The disease or disorder for which the drug was taken.
The mapping for a context item identifies the RefName path of the control whose data provides the context information. You can add, update, or remove a context item mapping. To add or update a context item control mapping, use either of the following methods:
- In the Data Mappings window, specify a RefName path. For more information, see Specifying a RefName path to add or update a context item path.
- Drag the control from the Form window to the Data Mappings window. For more information, see Dragging a control to add or update a context item path.
