Dragging a control to add or update a context item path
To add or update a context item control path by dragging a control:
- In the Trial Objects window, double-click the name of the coding mapping object.
The Data Mappings window opens with the mapping object name selected.
- In the Trial Objects window, double-click the name of the form containing the context item control for which you want to create or update a mapping.
- The Form window appears.
- In the Form window tree, expose the context item control.
- Drag the context item control from the Form window to the Data Mappings window and release it over the Context Item node where you want to create or update the mapping.
The Context Item Visit dialog box appears.
- Select the visit to use in the context item control path and click OK.
The InForm Architect application enforces restrictions on context item control path definition. For more information, see Context item control path restrictions. If the selected control results in a valid context item control path, the InForm Architect application inserts or replaces the context item control path in the Context Item node.
