Context item control path restrictions
The InForm Architect application enforces the following restrictions on context item control paths:
- The context item control path must be different from any code target control paths within a mapping.
- Verbatim, code target, and context item controls must be:
- In the same visit if the visit is repeating.
- On the same form if the form is repeating.
- In the same itemset if the coded data appears in an itemset.
- Different from each other.
