Setting up Oracle Clinical processing
To set up data transfer to the Oracle Clinical application, do the following:
- Define Oracle Clinical data mappings through the InForm Architect application.
- Produce a fixed-length or character-separated flat file of the mapped data using the InForm Data Export tool.
- Import the data mappings into an Oracle Clinical application.
Note: This section describes how to define and maintain Oracle Clinical mapping definitions in the InForm Architect application. For information on exporting data, see InForm Utilities Guide.
