About Oracle Clinical mappings
To specify how to transfer data from an InForm application trial database to an Oracle Clinical application for interim analysis, you create a set of Oracle Clinical mapping definitions.
The definitions of Oracle Clinical mappings specify:
- Where each mapped data point comes from in the InForm application source trial.
- The CPE Reference to which each data point belongs. A CPE Reference is a reference to a Clinically Planned Event, which corresponds to a visit in an InForm application trial.
- How the data is grouped in the Oracle Clinical application.
- Optional, supplemental text about the design of the components of the Oracle Clinical mapping definition.
The sections that follow describe the steps for defining Oracle Clinical mappings. Note that you must manually define the mappings; no auto-generate option is available. To define Oracle Clinical mappings:
- Create an Oracle Clinical mapping definition.
- Define CPE References.
- Define control mappings.
