Creating rules
This section describes the steps to take in creating rules:
- Create a new rule definition and specify its properties.
- Write a rule script.
- Define default arguments, if any, to pass to the script and specify their values.
- Create contexts by attaching the rule to each context item against which it runs, and define context properties.
- Define context-specific arguments and specify their values.
- Define additional dependencies or adjust dependency definitions as necessary.
