Creating a new rule definition
To create a new rule definition, select File > New > Rule. A new Rule window opens in the Design Workspace.
The Rule Profile tab of the Rule window displays a hierarchical view of the rule definition that provides access to the rule’s default arguments and to the contexts in which the rule is applied. As you define each context, the window shows the arguments and dependencies specific to the context.
Note: When using the InForm Unplugged software, it is important to make sure you synchronize rules before making modifications to them.
