Adding a default argument
To add a default argument:
- With the Rule Profile tab of the Rule window visible, right-click the Default Arguments node and choose Add from the pop-up menu.
The InForm Architect application adds a new argument line under the Default Arguments icon.
- In the Properties window, specify the following information in the Value column:
- Name of the argument.
- Argument type: String, Numeric (integer), Float, or Date.
- Value of the argument.
