Modifying a default argument
To modify a default argument:
- In the Rule Profile tab of the Rule editor, double-click the argument you want to modify.
- In the Properties window, edit the Value cell of any of the argument properties: Argument Name, Argument Value, or Argument Type.
Note: When you change the Argument Name or Argument Type, the InForm Architect application makes the same changes to each corresponding context-specific argument. In order to do this, it collapses the tree in the Rule editor.
