Specifying context-specific arguments and values
When you create a generic rule script, you set up parameters for values such as RefNames, comparison values, and constants. The InForm application passes in the values of context-specific arguments to these parameters when a rule runs against a context and its dependencies.
If you did not specify values for context-specific arguments when you defined the context, define them in this step. Any arguments defined for a specific context override the default arguments specified for the rule as a whole.
Note: When you define and update arguments for a specific context, you can only work with arguments that have previously been defined as default arguments. A context-specific argument must have the same Argument Name and Argument Type as its corresponding default argument. Therefore, the only context-specific argument property you can specify is the Argument Value.
