Adding a context-specific argument
To add an argument for a specific context and its dependencies:
- Click the Rule Profile tab of the Rule window.
- Expand the context for which you want to specify arguments.
- To add an argument, right-click the Context Arguments node and choose Add from the pop-up menu.
The Add Arguments dialog box opens, listing each default argument that has not been defined for the current context.
- Select each default argument for which you want to specify a context-specific Argument Value.
- Click OK.
For each selected argument, the InForm Architect application adds a new argument line under the Context Arguments node.
- To specify the Argument Value of the new argument, do one of the following:
- Select the argument. In the Properties window, specify the value of the argument in the Value column.
- Double-click the argument. In the RefName and Arguments dialog box, edit the Value cell for the argument and click OK.
Note: If you want the value of a string type argument to be a RefName path, you can click Build RefName to use the Build RefName tool, as described in Using the Build RefName tool.You can not specify a RefName path for the value of a date, float or numeric.
