Running interactively
To run a rule script interactively:
- Open the Rule window.
- In the Rules toolbar, click the Run Script (
) button.In the Get Item Value dialog box, InForm Architect application prompts you to specify the value of the first argument specified in the script:
- Specify the requested value, and click OK.
The InForm Architect application prompts you for the next value required by the script.
- As each prompt appears in the Get Item Value dialog box, continue to provide values and click OK.
Note: It may be helpful to open the Form window or windows containing the data items referenced by the rule, so you can see which items correspond to the values prompted for in the Get Item Value dialog box.
As the required values are entered, the InForm Architect application runs the script against the specified values, and reports the progress and results in the Rule Debug tab of the Output window.
