Running selected test cases
To run a rule script against selected test cases:
- Open the Rule window.
- Click the Test Cases tab.
- Select the cases you want to test by clicking the appropriate numbered rows on the left. To select multiple adjacent cases, hold down the Shift key and click the first and last case you want. To select multiple nonadjacent cases, hold down the Ctrl key and click each case you want.
- In the Rule toolbar, click the Run Selected Testcases (
) button.The InForm Architect application runs the script against the specified values, and reports the progress and results in the Rule Debug tab of the Output window. Cases with missing data are bypassed.
