Modifying the trial protocol HTML files
After you create the HTML files for the trial protocol, make the following modifications:
- Replace the </head> and <body> tags at the beginning of each file with the following Javascript function definition and call:
<script language="Javascript">
function OnLoad()
%s
</script>
</head>
<body ONLOAD="OnLoad()">Note: Do not include this Javascript function and call in the Table of Contents file.
- Search each file for percent signs (%), for example in table width specifications. Except for the %s string substitution command that appears in the OnLoad function definition at the beginning of each file, precede each % sign with another % sign as an escape character. For example:
- Search each file for exclamation points (!). To include an exclamation point in the text of the trial protocol, insert an additional explanation point as an escape character. For example:
- Use HTML formatting tags as necessary to create a document whose structure is clear and easy to understand. The following formatting conventions are suggested:
- Code the protocol title as an <h1> tag. For example:
- Code the name of each protocol section as an <h2> tag. For example:
