Creating a trial protocol
Step |
Description |
More information |
1 |
Create one or more HTML files containing the text of the trial protocol. One file per protocol section is suggested. |
2 |
Within each file, make code additions and changes required for processing by the MedML Installer utility. |
3 |
Create an XML file that defines the trial protocol in a DOCUMENTATION tag and as many DOCBODY tags as there are trial protocol HTML files. Use the BOOKMARKDOC DOCTYPE attribute. |
4 |
Create a Table of Contents file that includes each heading or subsection to which you want users to be able to link. |
5 |
Link each item in the Table of Contents file to the appropriate trial protocol HTML file. |
6 |
Associate the DOCUMENTATION definition with a study version. |
7 |
Process the trial documentation in the MedML Installer utility to load the files into the InForm database. |
Utilities Guide |
