Starting with the Base trial
The InForm application is delivered with a collection of predefined, required components used in all trials. These components make up the Base trial. When you install the InForm application and the InForm Architect application, the installation includes the loading of the Base trial files. Information contained in the Base trial includes:
- System resources, including images and HTML files used throughout the InForm application.
- System configuration settings.
- Predefined rights and default rights groups.
- Default query and signature groups.
- Predefined administrative users with rights to perform user administration tasks.
- Default numeric sequences for screening, enrollment, and randomization numbers.
- System form definitions (for example, definitions of Comment, Data Value(s), Query, Audit Trail, and administrative screens).
- InForm application online Help.
- InForm application reports.
When you install the InForm application, the sample trial scripts provided with the installation load the Base trial files along with the files that define the sample trials provided with the InForm application. The Base trial files are the foundation on which the rest of the trial is built.
