Customizing the application workspace
The InForm Architect application enables you to customize the appearance of the main application workspace for your maximum convenience. This section describes the customization options you can use:
- Toolbars—Display or hide toolbars, rearrange toolbar positions, move them in and out of the application window, and create custom toolbars that contain icons you choose.
- Windows—Display or hide windows, rearrange window positions, move them in and out of the application window, and minimize or maximize window size.
- Settings—Select View > Settings to affect Settings toolbar buttons and other options.
Note: The customizations that you make to the InForm Architect application workspace are for the duration of a session. They are not saved when you close and then reopen the application.
