Settings toolbar
The Settings toolbar enables you to specify system-wide InForm Architect application settings. These buttons are also accessible when you select View > Settings.
The following table describes each button in the Settings toolbar.
Button |
Description |
Install MedML When Saving—Run MedML Installer when you save trial component definitions. MedML Installer processes the XML generated during the save and loads the trial component definitions into the trial database. |
Strict MedML Checking—Enforce completeness of component definitions when you insert MedML into a trial or when you install MedML when saving. If you do not select this button, MedML Installer allows you to load partially complete component definitions into the trial database; for example, when you are in an early trial design phase. |
Toggle Rule Display—Determine whether the Form editor window displays rule attachments graphically. When you activate this option, the representation of each item includes a node that shows the rules attached to the item, along with the visits to which the rules are attached. |
Toggle Annotated View—Display CRF with metadata including: control reference name definitions, control data type and data format definitions, element definitions, date ranges, and (optionally) data mappings. |
Toggle Annotated Data Mappings Display—Display annotated Data Mappings information, if you have created a data mapping definition. |
Toggle Annotated Data Mapping Table Display—Display annotated data mapping tables, if you have created a data mapping definition. |
