Object Palette toolbar
The Object Palette toolbar enables you to create new visits or form components by dragging icons from the toolbar.
To create a new visit, drag the visit icon onto the appropriate location in the Protocol Editor window tree.
To create a new form component, drag its icon onto the appropriate location in the form design tree in a Form editor window.
The following table describes each button on the Object Palette toolbar.
Button |
Creates a new... |
Visit—To create the first visit in a trial, drag the icon onto the trial icon in the Protocol Editor window. To create a subsequent visit, drag the icon onto the visit that the new visit will follow. |
Association—To create an association, drag the icon onto the Associations selection in the Protocol editor Design tab. To associate repeating forms, drag the icons representing the repeating forms from the Trial Objects list onto the new association. |
Section—To create a new section, drag the icon onto the section that the new section will follow in the active Form editor window. |
Itemset—To create a new itemset, drag the icon onto the section in which you want to include it in the active Form editor window. |
Item—To create the first item in a section, drag the icon onto the section icon in the active Form editor window. To create a subsequent item, drag the icon onto the item that the new item will follow. |
Group control—To create a new group control, drag the icon onto the item or control in which you want to include it in the active Form editor window. |
Radio group control—To create a new radio group control, drag the icon onto the item or control in which you want to include it in the active Form editor window. |
Checkbox group control—To create a new checkbox group control, drag the icon onto the item or control in which you want to include it in the active Form editor window. |
Pulldown list control—To create a new pulldown list control, drag the icon onto the item or control in which you want to include it in the active Form editor window. |
Text box control—To create a new text box control, drag the icon onto the item or control in which you want to include it in the active Form editor window. |
Date/time control—To create a new date/time control, drag the icon onto the item or control in which you want to include it in the active Form editor window. |
Calculated control—To create a new calculated control, drag the icon onto the item or control in which you want to include it in the active Form editor window. |
Simple control—To create a new simple control, drag the icon onto the item or control in which you want to include it in the active Form editor window. |
