Trial toolbar
The Trial toolbar gives you access to the following trial component windows:
- Protocol editor
- Element editor window
- Mappings editor
The following table describes the buttons in the Trial toolbar:
Button |
Description |
Protocol Editor—Open the Protocol Editor so that you can create, update, or delete visits in a trial. |
Element Editor—Open the Element Editor window so that you can create update data element definitions. |
Create Data Mappings—Open the Create Data Mappings dialog box so you that you can create a new data mapping definition. When you click the arrow next to the button, a menu appears from which you can choose the type of mapping to create. |
