Rules toolbar
The Rules toolbar helps you to create and test rule definitions by allowing you to:
- Use context-specific arguments and test data when you run a rule in test mode, or select the patient against whose data you want to run the rule.
- Check the RefNames in a rule definition.
- Run a rule script.
The following table describes each button on the Rule toolbar:
Button |
Description |
Toggle RefName Check—Check the RefNames used in the current rule definition. |
Run Script—Run the current rule script interactively. You can also choose a patient and/or context with which to run the rule. |
Run Selected Testcases—Run the selected test cases from the current rule script. |
Run All Testcases—Run the entire current rule script, using data from the source specified in the pulldown lists in the Rules toolbar. |
Specify the patient whose data you want to use for testing a rule. Click the arrow to make the list drop down, then use the up and down arrow keys on your keyboard to scroll through the list. |
Specify the context containing the data you want to use to run a rule. If you select No Context selected, the InForm Architect application runs the rule by using the default arguments and values specified in the rule definition. |
