Edit toolbar
The Edit toolbar provides tools for editing the text in the MedML or Script tab of a component definition window.
The following table describes each button on the Edit toolbar.
Button |
Description |
Undo—Reverse the previous action. |
Redo—Reinstate the action you previously reversed. |
Find—Search for a specified string in a text window (the MedML or Script tab of a component editor window). When you click the Find button, a Find dialog box opens so that you can specify search criteria. |
Find Next—Repeat the previous text string search. |
Toggle Bookmark—Create or remove a bookmark at the cursor location in a text window. This button enables you to mark or unmark a specific line in the MedML or Script tab of a component editor window. |
Next Bookmark—Jump to the next bookmark in a text window. |
Previous Bookmark—Jump to the previous bookmark in a text window. |
Clear All Bookmarks—Clear all bookmarks from a text window. |
