Main toolbar
The Main toolbar enables you to:
- Create a new trial, form, rule, event, execution plan, element, or unit.
- Open a trial or a MedML file.
- Save trial components.
- Cut, copy, or paste text or component definitions.
- Print.
- Display the InForm Architect application online Help.
The following table describes each button on the Main toolbar:
Button |
Description |
New—Create a new trial, form, rule, event, execution plan, element, or unit. When you click the New button, one of the following happens:
Open Trial—Open a trial. When you click the Open Trial button, the Open Trial dialog box appears, and you can select the trial you want to open. |
Insert MedML—Open an .xml or .rsp file. When you click the Open button, the Open dialog box appears, and you can select the MedML file you want to open. |
Save—Save the trial component in the active editor window as an .xml file. When you click the Save button, the Save dialog appears, and you can specify the name of the file in which you want to save the component definition. |
Save All—Save generated XML and files and response file for all trial components in cache, whether or not they are used in the active trial definition. When you click the arrow next to the button, a menu appears from which you can choose how you want to save the trial:
Cut—Cut the selected text or form component from the location where you have selected it. |
Copy—Copy the selected text, visit, or form component from the location where you have selected it. |
Paste—Paste the contents of the clipboard into a selected location. |
Print—Print the contents of the active window. |
About—Display the InForm Architect application online Help. |
