Docking and undocking windows
By default, the Output, Properties, and Trial Objects windows are positioned (docked) in panes of the application window. You can convert them into moveable windows and position them anywhere on the screen.
To undock one of these windows and change it into a moveable window, drag its repositioning handle out of the pane where it is located. When you release the mouse button, the window’s appearance changes to a moveable window with a narrow title bar. You can use the title bar to drag the window anywhere you want on the screen.
If you release the mouse button when the window is near a defined pane, the window snaps to a docked position against the pane.
To return a window to its original docked position, drag its title bar back into the window’s original pane. When you release the mouse button, the window snaps into the docked window position closest to the cursor.
Note: To prevent a window from being docked when you drag it near its pane, hold down the Ctrl key while you drag the window.
