Displaying and hiding windows
By default, the Output, Properties, and Trial Objects windows are visible when you start the InForm Architect application.
To hide a window, use any of the following methods:
- Deselect the window name from the View menu.
- Right-click in the window, and choose Hide Window from the pop-up menu that appears.
- Click the Close button
in the upper right corner of the window.
To restore the display of a hidden window, select the window name from the View menu.
