Properties window
The Properties window is an editor in which you define or update the properties of a specific trial component. This window displays the properties of the component that is selected in the active window in the Design Workspace or of the component that is selected in the Trial Objects window. The Properties window appears by default in the lower left side of the application window. It consists of the Properties tab, which is always visible, and the Mappings tab, which is visible when you select a mappable control in the Form window.
