Properties tab
The Properties tab is the default view of the Properties window. This tab is available for all types of trial components. It consists of a table in which the property name appears in the Property column and the value of the property appears in the Value column.
To edit the definition of the property, click the appropriate cell in the Value column and type or select the value you want to specify. If a property has a set of known values, when you click the value cell, a pull-down list appears, and you can select a value from the list. For some properties, you must select multiple values. In these cases, a list of checkboxes appears when you click the property’s Value cell, and you can select each value that applies.
The following figure illustrates the Properties tab of the Properties window.
