Dragging and dropping mapped controls
You can drag a control from a Form window onto a data mapping table or column to which you want to map the control, as an alternative to using the commands on the right-click menu for a table or column.
Copyright © 1998, 2015 Oracle and/or its affiliates. All rights reserved.
