MedML tab
The MedML tab provides a read-only display of the MedML tags that define the data mapping. As you create, update, or delete the components of a data mapping definition, the InForm Architect application updates the corresponding MedML tags.
To open an online help file containing detailed information about each MedML tag, select Help > MedML Help.
