Using the Properties window
To modify a trial component definition, change the values of its properties as necessary.
To change a specific property:
- In the Design Workspace, open the editor window containing component whose properties you want to edit, and select the component.
- In the Properties window, click the Value cell that corresponds to the property you want to change:
- To change a text property, edit the text in the Value cell, and press Enter.
- To change a selected property, click the Value cell to reveal a pull-down list of selections then click the new selection in the pull-down list and press Enter.
- To change a property requiring multiple selections, click the Value cell to reveal a pull-down list of selections then click each check box selection that applies and press Enter.
