Modifying element definitions
To change element definitions, use the Element Editor window.
To open this window, do any of the following:
- Select Trial > Elements.
- Click the Element Editor button on the Trial toolbar.
- Double-click an element in the Trial Objects window.
To change a property in this window, click the cell you want to change and type or select a new value. For more information, see Defining element components.
