Opening an existing trial
To open a trial:
- Select File > Open Trial. As a shortcut, you can click the Open Trial button
on the Main toolbar.The Open Trial dialog box appears.
- In the Select Server/Trial list, select the trial you want to open.
- Click Open.
When you open a trial in the InForm Architect application, the application checks whether the trial is currently running:
- If the trial is not running, the InForm Architect application starts it.
- If the trial is running, the InForm Architect application attaches to it.
Note: If you install the InForm Architect application after installing the InForm application and starting a trial, you must stop and restart the InForm service before you can connect to the trial through the InForm Architect application.
