Closing a trial
The InForm Architect application enables you to work with one trial at a time. Before you can open a different trial, you must close the trial you are currently working with. To close a trial:
- Select File > Close Trial.
- Click OK.
Copyright © 1998, 2015 Oracle and/or its affiliates. All rights reserved.
