Inserting MedML into a trial
The InForm Architect application enables you to insert MedML component definitions into a running trial. You can insert either of the following types of files:
- An XML file containing component definitions
- A response file (.rsp extension) containing the names of XML files to insert
Once you have created a new trial or opened an existing trial, insert MedML by doing the following:
- Select File > Insert MedML.
- Use the Open File dialog box to select a previously defined XML or response file.
- Click Open.
The InForm Architect application loads the component definitions into the trial, where they become available for selection in the Trial Objects window.
