Specifying additional paths
When you create a .rsp file, you specify the location of each .xml file to load relative to the location of the .rsp file. The MedML Installer finds the XML files by using the path information in the .rsp file. If you attempt to insert individual XML files, the MedML Installer may be unable to resolve references to other files—for example, if you load user images in a set of user definitions.
To handle this situation, the InForm Architect application enables you to specify additional paths where XML files are located. When the MedML Installer processes an XML file, it searches each of the specified paths to find the files it requires.
To specify additional paths:
- Select View > Settings > Additional MedML Path.
- In the Additional Path dialog box, enter each additional path where MedML should search for files referred to in the XML files you want to process. Separate path names with semicolons.
- Click OK.
