Specifying strict MedML processing
To install trial component definitions into the database while saving trial components, the InForm Architect application activates the MedML Installer utility. During the trial design process, you may want to be able to load definitions that are not entirely complete. Later, you may want to ensure that the definitions you load are fully compliant with the MedML specification. The InForm Architect application accommodates both of these modes with the Strict MedML checking button
on the Settings toolbar:
- To specify that you want the MedML Installer to check that all required parts of a component definition are present when you save and install trial component definitions, select the Strict MedML checking button on the Settings toolbar. In this mode, the MedML Installer does not load a form if it does not have a section, a section if it does not have an item or itemset, an item if it does not have a control, and so on.
- To specify that you want the MedML Installer to load partial definitions of components, leave the Strict MedML checking button in the unselected state.
