Installing the sample trial
If you set up either sample trial when you install the InForm application, the sample trial is available for opening when you start the InForm Architect application.
Alternatively, you can use the InForm Architect application to install the sample trial as follows:
- Select File > Insert MedML.
- Use the Open File dialog box to browse to the \InForm\Sample_Trial\FastStart directory in the InForm application installation.
- Select the protocol.rsp file
- Click Open.
Note: To see when the sample trial installation is complete, watch the messages in the output window.
