Right-clicking the association
To add repeating forms to an association by right-clicking:
- Right-click the association and select Add Form from the popup menu.
The Add Form to Association dialog box opens and displays the repeating forms that have been defined for the trial.
- Select one or both of the forms that you want to include in the association.
The Add Association Form dialog box opens.
- Select the visit for the first form in the association, and click OK.
- Do one of the following:
- If you selected both forms in the Add Form to Association dialog box, the Add Association Form dialog box reappears. Select the visit for the second form in the association and click OK.
- If you selected only one form in the Add Form to Association dialog box, repeat the entire procedure to add the second form to the association.
