Dragging and dropping forms
To add repeating forms to an association by dragging and dropping forms:
- From the Trial Objects window, select, drag, and drop a desired form into the new form relationship.
The Add Association Form dialog box opens.
- Select the visit for the form, and click OK.
Note: Once you have set up an association and installed it in a study version, you cannot change or remove it.
