Overview - Creating CRF Help links
To create links to CRF Help:
- Create CRF Help files. One file per CRF is suggested.
- Create bookmarks in the CRF Help item description.
- Define a HelpLink component by using the HELPLINK tag and pointing to the CRF Help description. A HelpLink component is a pointer from an Item definition to a bookmark in a CRF Help file or from a form definition to a CRF Help file.
- Include the HelpLink in the CRF Help document as a child component of the item or the form to which the CRF Help description refers.
Note: To create the item or form definitions for which you are providing CRF Help, you can use the InForm Architect application. To create CRF Help links, you must manually add the required MedML tags to the XML form definition files generated by the InForm Architect application, as creating CRF Help and links is not supported by the InForm Architect application.
