RANDOMIZATION table
The RANDOMIZATION table indicates which randomization types are in use in the trial. This table has the following columns:
Column name |
Data type |
Description |
ID |
Number, primary key |
Number that corresponds to the randomization type number:
Type |
Text |
Name of the randomization type; one of the following:
InStudy |
Boolean |
If true, indicates that the corresponding randomization type is being used in the current trial. |
