SOURCELISTS table
The SOURCELISTS table corresponds to the randomization SequenceTypes entered into the InForm application database with XML and the Trial Set-up Tool. This table has one row for each randomization list used in the trial. The table has the following columns:
Column name |
Data type |
Description |
ID |
Autonumber, primary key |
Sequential list identification number that maps to the ListID in the DrugKits table. |
ListName |
Text |
Name of the drug kit list. The randomization rule must populate the Randomization.Source property with this name. |
SequenceUUID |
Text |
UUID of the SequenceType to which the drug kit list corresponds in the InForm application database. Note that Alphabetic characters in required UUIDs must be uppercase. |
Max |
Number |
Maximum number of drug kits. |
MaxAllowed |
Number |
Maximum number of drug kits that can be used during the trial. |
TypeID |
Number |
Identification code of the randomization type. This value maps to the ID column in the Randomization table:
