DRUGKITS table
The DRUGKITS table holds drug kit information for each randomization source list. This table has the following columns.
Note: Special configuration may be required if you are using the Central Stratified randomization type. For more information, see Setting up Central Stratified randomization.
Column name |
Data type |
Description |
ID |
Autonumber |
Sequential drug kit identification number. |
Description |
Text |
Drug kit information. If the randomization rule so specifies, this information is appended to the randomization number that the InForm application generates. |
ListID |
Number |
Number that maps to the ID in the SourceLists table and enables the randomization source data manager to get the correct drug kit string. |
SequenceNumber |
Number |
Randomization sequence number in the list identified by the ListID number. |
