Populating randomization source database tables
For each trial, you must populate the tables of the randomization source database with the information about each drug kit that will be available for use in the trial, as follows:
- In the Randomization table, specify the type of randomization to be used in the trial.
- In the SourceLists table, enter the source name and sequence UUID, copied from the .xml file used to enter SequenceTypes into the InForm application database, for each drug kit list.
- In the DrugKits table, enter information about each drug kit to be used.
Note: As a suggested convention, include the name of the trial in the name of the randomization source database, and store the database in the trial directory in the InForm application installation tree.
The sample Microsoft Access database PFST_Rnd.mdb distributed with InForm application provides a template for the randomization source database.
Note: The randomization source database must physically reside on the same machine as the InForm application Server; you cannot map it to the InForm application Server machine by using a network drive.
