Configuring a randomization data source
After creating a randomization source with the Windows ODBC manager, Use this procedure to configure a randomization data source:
- In the ODBC Text Setup dialog box, enter the DSN of the randomization database as the Data Source Name. As a suggested convention, include the name of the trial in the name of the randomization source database; for example, if the trial name is PF304, you can name the randomization DSN PF304RND.
- In the Database section of the dialog box, click Select Directory, and select the randomization source database from the directory where it is stored.
- Click OK in each dialog box.
