Creating an ODBC connection with PFAdmin
The PFAdmin utility is a command-line tool included in the InForm application installation to help with setting up a trial and the InForm application server. To use PFAdmin to create a DSN for the randomization database automatically:
- Open a Windows command window.
- Change to the \bin directory in the InForm application installation.
- Enter the following command:
PFAdmin config trial <TrialName> /Rnd [<MDBFilePath>
[UID] [PID]]where:
- TrialName is the name of the trial.
- MDBFilePath is the full pathname of the Microsoft Access randomization source database.
- UID is username of the trial schema owner.
- PID is the password of the trial schema owner.
For example:
PFAdmin config trial PF304 /Rnd
F:\InForm2\Trials\PF304\Template\RndPF304.mdb
pf304db pf304db
